Results 1 to 8 of 8
Thread: Factory Five Mark3 Roadster
    Norton, MA USA earth
    Up for sale I have a 0 mile Mark3 Roadster. Build was just finished. Still on original MCO
    asking $35,000.00 or best offer.
    Engine:
    390 Big block new engine
    Aluminum heads
    Mechanical fuel pump
    4 barrel carb
    Canton Race pan
    FFR 4 into 4 headers
    MSD ignition
    FFR aluminum radiator
    Degas tank
    Custom radiator hoses
    Cobra oval air cleaner
    Cobra valve covers
    Transmission:
    Tremec TKO with mid shift conversion
    Steel bell housing
    New clutch flywheel and related parts
    New heavy duty driveshaft
    Short throw shifter
    Front suspension:
    Front FFR supplied upper and lower control arms
    Koni shocks
    SN95 spindles and new hubs
    11 inch front disc brakes.
    Stainless flex brake lines
    Powdercoated calipers
    Rear:
    FFR supplied 3 link setup with Koni shocks
    Rebuilt 8.8 with 3:55 gears
    Powdercoated housing
    Disc brakes
    Powder coated calipers
    Exterior:
    Front and rear bumpers
    Chrome roll bar
    Roll bar trim rings
    Stainless side pipes
    FFR upgraded side louvers
    Replicaparts nose aluminum
    FFR supplied wiper kit
    Interior:
    New upgraded FFR vinyl dash with glove box
    Speedhut gauges
    Fully insulated interior
    FFR big and tall seats
    Seat belt tri plates
    Russ Thompson turn signal system
    Heater and defrost system
    Driver seat slider
    Finished trunk.
    FF metals firewall forward kit
    Wiring:
    Car is wired with a Painless harness that includes Weather-pack connectors at all lights. Dash is connected with 2 plugs so that it can be removed for service if needed.
    FF Metals battery box in the trunk
    Optima red top battery
    Wheels and tires:
    Torque Thrust 17 inch wheels with custom “5” center caps 9 inch in front and 10.5 in rear
    Tires front:
    BF Goodrich 245/45-ZR17 G force sport
    Rear 275/40-ZR17
    Gainesville, VA
    Beautiful!
    Great looking car! Can you add pics of the motor - currently putting a 390 together and need inspiration!!!!
    TTT still available.
    Fantastic car!
    PM sent
    Car looks awesome!!!
