Results 1 to 15 of 15
Thread: Front wheel well splash panels - keep or not?
    Huntsville, AL
    Are people installing the front inner fender splash panels, the ones that go behind the front wheels in front of the doors, or leaving that area open to vent air from the front wheel well on an 'R'?
    Skip
    Bowling Green, KY
    Skip, I intsalled mine with rivnuts to allow removal.
    Quote Originally Posted by lclevert View Post
    Skip
    I ran without them on my "S" for a while. There were some holes the let pebbles and sand off the tires accumulate in the foot well areas. At speed it would blow around in the cockpit. So I installed them.
    The "r" might be different as your side thin aluminum stays high to the front of the cockpit.
    If your going with the door vents. You would have to do something special anyway.
    Kirkland, WA
    With an R and using the side rear vents you want to allow the surface air to flow and putting those panels on would prevent that
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    Bowling Green, KY
    Tony, I just put the panels in to block off the front of the chassis, I didn't block off rear vent.
    Huntsville, AL
    Mitch,
    Did you just leave off the "elephant ear" panel that goes behind the front tire and in front of the door?
    Bowling Green, KY
    IMG_0070.JPGIMG_0071.JPGWhat I did was cut them down and rivited to the door to protect the fiberglass, I will run out and take a photo and post.
    Huntsville, AL
    Thanks for the pictures. I was thinking of doing something similar to protect the door but leave the opening to vent. It looks like you didn't install any front splash shield either, just the radiator aluminum.
    Bowling Green, KY
    Correct have made some small panels to keep crap out of head lights
    Didn't use, just a protector for the door
    Kirkland, WA
    I have installed and the side splash panels and the front wheel well guard just not the rear wheel well guard but may do something like Retro did and just cover door
    Tony Nadalin
    If you don't use them, you will get ALL KINDS of crap in the cabin.
    Kirkland, WA
    ??? The area is all sealed if you used the aluminum side panels or you have anti intrusion protection
    Tony Nadalin
    San Diego Ca 92106
    Wire mesh and or louvers?
    Good point - I missed the fact that this was an R. I have an S so it's different. There are no side panels and there are gaps where stuff can get in, even if you have all the interior panels installed. My racing seats are already so dirty... they will never ever become fully clean. Though part of that is the type of fabric the seats are covered with. It's like velcro for dirt.
