Results 1 to 15 of 15
Thread: Windshield frame stiffening?
    Edmonton, Alberta
    We all know the frame is pretty flimsy, but being hollow throughout, couldn't we do something about that? Like injecting expanding foam with a long hose or something? And since the steel only goes so far into the frame, could we stick a piece of round stock up to the corners and weld them to the mounting flanges? Obviously the windshield should be attached before doing so, I'd hate to stiffen it to the wrong shape.
    It's just that I know I'm going to be yelling at people trying to use the windshield as a grab handle to get in and out, and I'd like to avoid a broken frame or windshield. Thoughts?
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
    The solution of filling the vertical tubes is similar to back surgery where the spine is fused. The windshield will be stiffer but not necessarily stronger.
    San Diego Ca 92106
    I'm considering incorporating a grab handle on the dash like early corvettes. A composite of the 1960 and 65 corvette.
    QC, Canada
    What type of foam would stiffen the surround?
    Also many have the windshield glass already on, ideally if there could be a solution that does not require the glass to be off that'd be good too.
    The dash is weaker than the whindshield, I guess you'd have to attach the handle to the frame.
    Tracked May 27/July 26, 2017
    Build Completed Winter 2021
    Freeport, ME
    I drilled into the windshield frame and inserted a couple roll pins on each side. The lever is so long that without them you can rotate the windshield around those two 1/2 bolts, no matter how long a pipe you use to tighten it. Some sort of irregular surface (grooves?) on the surface would help too but the powder coat makes it easy to slide.
    Dan
    San Diego Ca 92106
    The roll pin is a great idea for setting and maintaining the angle of the windshield. It may also contribute to breaking the windshield if someone grabs the windshield to get out of the car.
    The only solutions I can think of would be to cut the windshield frame to reinforce it some how, add a grab bar to the frame and integrate it to the dash, or add a roll cage with the front roll bar behind or incorporated in the windshield frame.
    What do you guys think?
    Mechie3's Avatar
    Indianapolis
    For now I have no passenger seat so no one to grab it. In the future I plan to put a sticker there that says "not a handle" or "no grab", etc.
    Zero Decibel Motorsports
    Check out my new website!
    QC, Canada
    NO GRAB. hahahahaha, I know exactly where I'd stick that. lolll
    Dan it's a good idea, I think I'll drill holes too and insert some bolts, as tight as possible.
    Freeport, ME
    if it breaks it gets replaced for $50 on my insurance no big deal. I had it swing downward twice with riders trying to use it as a handle and it brings the bottom edge into the top of the door
    Dan
    San Diego Ca 92106
    Dan, I saw your post in the ask a tech sectionhttp://thefactoryfiveforum.com/showthread.php?24609-818S-windshield-header-construction-top-mounting what do you think of cutting a slot across the width of the windshield with vertical slots to accommodate the insertion of a length of metal that has been drilled and taped for a series of bolts. then inject adhesive into the slot. Next slide the length of metal with the bolts with nuts and washers added into the slot then use the nuts and washers to hold the metal against the inside of the windshield. when the adhesive has cured the windshield can be repaired filling in the slots. A lot of work to do for sure and perhaps a thinner length of metal with rivnuts would be better. just an idea I had . is this overkill? thoughts ?
    Senior Member AZPete's Avatar
    Here's a post from a very knowledgeable guy, Blwalker105, that explores adding strength to the FFR hardtop, but may also apply to the S windshield. Bill explains injecting the windshield A pillars and the resulting rigidity.
    http://thefactoryfiveforum.com/showt...-reinforcement
    Freeport, ME
    Flynntuna, holy crap, that's a load of work! Tom Wallace says he used rivets for the FFR soft top... I'll come up with something to attach the bikini to
    Dan
    San Diego Ca 92106
    Yeah, maybe overkill. Perhaps a piece of aluminum or steel 1x2 at each point of attachment would be enough. I just don't trust a rinut in the fiberglass would be enough to hold the top at 70mph.
    Freeport, ME
    I'm thinking 8-10 3/16 pop rivets
    Dan
    San Diego Ca 92106
    I'm over thinking this, for what I'm thinking of doing using a top like what is used in the viper, a simple clamp style like what FFR uses will work. The top will overhang the windshield frame and will be clamped to the bottom with a screw type clamp. Something similar around the roll bar should be enough. I think
