moving towards getting this to crank and make some noise....
Wiring is about 80% done... I am going to get it running with all the stock switches first then wire up the cyclic stick... Engine went in today for the FINAL time... while I was at it I went ahead and recycled the 2015 clutch tubing..fit nice. All I had to do is re-bend one line and it all worked out... I can go ahead and put brake fluid and clutch fluid in tomorrow. The Coyote Harness is 100% laid into the Ron Francis Harness... will work the seat heaters tomorrow as well as start working the custom driveshaft I need built. Looks pretty cool.
I had a couple people ask me about the MT82 tranny and how far it hangs below... so here are some more shots..
From the front... oil pan JUST below the frame:
from the side... the angle makes it worse than it is.... and now I am noticing some surface corrosion that needs to be taken of ...
Custom Made MT 82 tranny mount
Hydraulic Clutch line peeking out
getting ready to mount the intercoolers!
