Page 6 of 11 FirstFirst ... 45678 ... LastLast
Results 201 to 240 of 427
Thread: Gen 3 "Blackhawk" Coupe Build
  1. #201
    Huntsville, Al
    So, with my intercoolers taking up the spot where I am sure the AC/Heat unit is supposed to go.... more out side the "box" thinking was required.
    While Wayne was up here last we kicked around a lot of ideas...this one made the most sense....
    I will run the ducting back up into the back of the cabin. The defrost ducts will merge together and go through the tunnel up into the dash and split in two....
    I have to make a custom fan box to rotate the blower so it draws air from the trunk... but I will do that with the body off.
  2. #202
    Huntsville, Al
    Why the drive shaft slip joint? Just happened to be easy due to parts on hand?
    The stock driveshaft has a slip joint between the tranny and the first universal hanger bearing that is fixed to the chassis.... That is the section that I was copying or adapting... this allows the engine and tranny to move freely since I don't have a slip joint on the tranny end. It's hard mounted on each end.... hard to see in the picture.... here you can see the 3 bolt flange that I had to attached the universal to with another adapter that converted the 3 bolt flange to a 4 bolt plate that the universal is bolted to....
  3. #203
    Huntsville, Al
    Big day today! ..... drove... yes drove it out of the garage....!!!!!
  4. #204
    Port Charlotte, FL
    Awesome Chief. Looks great and congrats on the mini go kart!
    Henry
  5. #205
    Ol Skool
    upstate NY
    Great job! What's next??
  6. #206
    Mark Dougherty's Avatar
    Hershey PA
    wow
    Congrats Eric
    I did the rear mounted ac on a roadster years ago
    worked out fine
    The traveling Builder
    717-773-5624
  7. #207
    Huntsville, Al
    Sweet... thanks for that
  8. #208
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    Looks great!!!
  9. #209
    Member Paul G's Avatar
    Glendale Arizona
    Looking great. Hope to have ours sitting on it wheels this weekend so I can roll it out of the garage so I can get the Roadster ready for Huntington Beach next weekend.
  10. #210
    Fayetteville WV
    Erik,
    The Coupe looks fantastic! Nice innovations.
    Thanks, Len
    1972 Corvette Stingray 350 c.i. Manual Steering & Brakes
    2003 H-D Softail Deuce 88 c.i. TwinCam
    Gen 3 Coupe Dreamer
  11. #211
    Super Job!
  12. #212
    Huntsville, Al
    Initial Drive down the street to validate "go-cart" status... rough alignment is in, brakes seem ok, windshield and hatch fit... couldn't hammer down, no belts and no tune... so more to follow...
    video:
  13. #213
    Fayetteville WV
    Super Nice!! Great sounding pipes. Thanks!
    Gen 3 Coupe Dreamer
  15. #215
    Administrator
    Enterprise Alabama
    Very nice, sounds great
  16. #216
    Great work, Erik! Sounds nasty!
  17. #217
    Huntsville, Al
    It is definitely loud... but does sound pretty mean or angry
  18. #218
    Fayetteville WV
    Quote Originally Posted by erik w. Treves View Post
    it is definitely loud... But does sound pretty mean or angry
    MEAN! Get out of my way, I'm coming thru, FAST!
    Gen 3 Coupe Dreamer
  19. #219
    Hershey PA
    fantastic Job Eric
    congrats
    717-773-5624
  20. #220
    Erik-
    Looks and sounds awesome. Congratulations on coming so far so quickly, although that's nothing new for you!!
    I always enjoy following your builds. Always lots to learn, and always a quality build!
    Keep up the great work.
    Senior Member HCP 65 COUPE's Avatar
    NORTH CENTRAL CT
    Congrats on the go kart man you sure are moving fast.
  22. #222
    NORTH CENTRAL CT
    Did FFR change the lemans gas cap?
  23. #223
    Sep 2015
    Beachside
    If I do another FF, it will definitely be the coupe. Looks and sounds great!
    FFR #8833 289 FIA 3-link
  24. #224
    Huntsville, Al
    Quote Originally Posted by HCP 65 COUPE View Post
    umm... no.... Erik changed the gas cap
  25. #225
    Aliso Viejo, CA
    Sounds awesome man!
  26. #226
    Great progress & I love the oval pipes.
  27. #227
    Congratulations, Mamba won best of show at HB.
  28. #228
    Huntsville, Al
    Thx... very cool... I miss that car
  29. #229
    Those pipes are the best! I wasn't sure if anyone would ever create a really good looking set for that car. They don't sound bad either.
    WEK.
  30. #230
    Nov 2016
    by any chance did spintech mufflers make the side pipes for you?
  31. #231
    Huntsville, Al
    THey are not spintech mufflers... the design of the exhaust is pretty nice sounding but they are a little loud for me and a little surprising given the turbos...Wayne and I are going to try some things on the dyno to see if we can quiet them down some.... right now the 2.5 in pipe feeds into a 3 inch transition which dumps into the oval pipe which is about 6 inch... I think it's acting like a megaphone .... so we will see... sounds awesome though.
  32. #232
    Wish we would've seen it ripping up and down the PCH with us.
  33. #233
    Huntsville, Al
    Quick update.... body is at paint... still have work left to do on the dyno so that will finish up later.. initial setup has the tune in it for larger injectors now...
    mean while back home... started finishing up the wiring to include the shifter which will allow me to start the interior...
    here is the video thus far of the Blackhawk Helicopter cyclic grip working all the functions.... still have to wire up the turn signals and hazards... those are next on the list... rather than go through a detailed list of what I did.... here is the video..
  34. #234
    Hershey PA
    Eric any numbers on the engine yet
    717-773-5624
  35. #235
    Huntsville, Al
    umm... no.... we ran into a few issues that we are working on....so I brought the car back home and will finish up everything else and look at going back down as the body is finished..... more to follow.
  36. #236
    Crystal MN
    If you ever sell this car you'll need to provide a video on operation
  37. #237
    Erik-
    Love the use of the cyclic!! I am doing something similar for my F-18 inspired build. I think it adds a lot of style!
    Great progress, and as usual, plenty fast build! It's looking great.
    Huntsville, Al
    a few more, small/big steps.... wiring is J_U_S_T about done... finished up the cyclic wiring...done... I have made the stick connection quick release incase I need to pull the tranny and such... one click and the stick is disconnected from the car. I also made a boot and recycled a shifter ring... I then moved to the AC unit since the body is off at paint... I think/hope this should work good....I also started putting in insulation/sound deadening...... I had to reposition my driver's side wastegate to make room for my cold air intake.... I had a 3inch piece of silicon that transitioned to 2 inch and it choked the crap out of the turbo...so now I have 3 inch all the way.... but had to do some welding...again...anyway... enough of that.... these are small pieces down but they were keeping from some major progress.... so here ya go...
  39. #239
    Scottsdale, Arizona
    Erik, You've got a fascinating build underway. I'm growing to like your large single side pipes and would appreciate knowing what the basic dimensions are of the "rectangular-oval" pipe (width & height). What do you have in the way of muffler inside the side pipe? It looks like there is one large central "muffler" section with smaller sized entry and exit tip pipes, but in your discussions you don't mention if there is one.
    Currently in the dream & planning stage with aspirations
    to soon buy a Gen 3 Type 65 Coupe Kit
    Former fabricator, designer & crew member of Trans-Am, Can-Am & IMSA GT cars in 70s
  40. #240
    Huntsville, Al
    Bob. The mufflers are 30 inch 6 3/4 oval with VERY little sound proofing in them... they actually are very loud... we put some vee diverter metal pieces in them to beat down the sound.... they do sound awesome
