Page 4 of 11 FirstFirst ... 23456 ... LastLast
Results 121 to 160 of 427
Thread: Gen 3 "Blackhawk" Coupe Build
  1. #121
    Huntsville, Al
    moving towards getting this to crank and make some noise....
    Wiring is about 80% done... I am going to get it running with all the stock switches first then wire up the cyclic stick... Engine went in today for the FINAL time... while I was at it I went ahead and recycled the 2015 clutch tubing..fit nice. All I had to do is re-bend one line and it all worked out... I can go ahead and put brake fluid and clutch fluid in tomorrow. The Coyote Harness is 100% laid into the Ron Francis Harness... will work the seat heaters tomorrow as well as start working the custom driveshaft I need built. Looks pretty cool.
    I had a couple people ask me about the MT82 tranny and how far it hangs below... so here are some more shots..
    From the front... oil pan JUST below the frame:
    from the side... the angle makes it worse than it is.... and now I am noticing some surface corrosion that needs to be taken of ...
    Custom Made MT 82 tranny mount
    Hydraulic Clutch line peeking out
    getting ready to mount the intercoolers!
  2. #122
    Senior Member HCP 65 COUPE's Avatar
    NORTH CENTRAL CT
    Eric,
    How hard is it going to be to get to that fuel pressure regulator later on?
  3. #123
    Huntsville, Al
    Shouldn't be an issue
  4. #124
    Thanks for posting the pics because I was really interested in seeing how far, if any, the driveline protruded below the frame.
    If I had 1/2 of your skills the GoDadGo MK-4 would be running.
    This car is really going to be something special!
  5. #125
    Mark Dougherty's Avatar
    Hershey PA
    Eric
    looking fantastic.
    The traveling Builder
    717-773-5624
  6. #126
    Huntsville, Al
    Didn't get as much done today... had a few visitors and some friends came over.... so got the intercooler mounts made... one intercooler color matched to the car color... looks pretty good... had planned on measuring up the driveshaft, but that is a next weekend thing I suppose. anyway....
  7. #127
    Hi Erik, really enjoying your build process and the pictures. I will be ordering one in April so really looking forward to building it. I am new to the site and no one has built a Coupe down here in New Zealand. I have seen your order to Factory Five but it would be really interested if you or anyone on the thread had a full list of all the items that i would need to buy to build the car??? Cheers Graeme.
  8. #128
    Milton,DE
    Erik,
    Did you mount the engine lower for any reason? Or is that where it just sits? The reason why I ask is that the oil pan being even that little bit below the frame would be an automatic fail at NJ title inspection.
    Olli
  9. #129
    Huntsville, Al
    Everything just landed there Olli. You could shim it up I suppose
  10. #130
    Nashua, NH
    Erik, did you shim up the motor mounts? I believe the kit comes with shims you put in the motor mounts
    http://johngeorgeracing.com
  11. #131
    Huntsville, Al
    I did not see the shims in the kit.... do you remember what box they were in?
  12. #132
    Huntsville, Al
    I know the roadster comes with a shim kit... not sure I saw the one in the coupe box
  13. #133
    Huntsville, Al
    Olli, turns out I was missing the motor mount spacers..... thanks to you and John and jim.... they are on the way... I will mount them and show the after picture
  14. #134
    Erik
    With that powerplant it should be the most powerful coupe to date. Any plan to do a top speed run or a standing mile run with it?
    With your final drive ratio what speed would redline be IF the COD doesn't win the battle?
    Love watching the build.
    Dale Berry
    7Liter Hemi33
  15. #135
    Huntsville, Al
    Geez... I don't know....THe Green Lantern was a handful....we'll see I suppose....for sure it is going to the 1/4 mile track.... I mean it has a line lock....so a burn out or 4 will be required.
  16. #136
    Erik,
    Another Huntsville guy here (Madison actually). Would love to come over and see the build sometime. I'm currently converting a 96 Mustang to Coyote power but these builds are very interesting. If I can convince the wife maybe this will be next.
    Byron
  17. #137
    Trick Tool Maker, Super Moderator Hankl's Avatar
    Northern CA
    Was just waiting for the Roaster mindset to evaporate,
    Raise your right hand and say after me,
    "I (State your name), do swear/affirm, that upon acceptance of this "Revered Coupe Jacket", will willingly subject myself to all manner of frustration and abrasion that my FFR Type 65 will provide. I further pledge that any and all fellow Coupe builders will have free reign in using the cash available in my wallet as they see fit to improve my build plan. I will not look down upon our fellow Roadster builders, but rather take pity on those not talented enough to build a race car with a roof, So Help Me God!"
    It is my pleasure to present you with the "Revered Coupe Jacket", Here's your sign!!
    Hankl
    “If you didn’t have enough time to do it right the first time. How come you always have time to go back and do it again?” FFR1000186CP
    Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car.
    Horsepower is how fast you hit the wall and torque is how far you take the wall with you.
  18. #138
    Huntsville, Al
    Come over any time...phone is 334 494 0764
  19. #139
    Hank, is that my jacket? If so I'm honored. And a bit scared.
    Thanks Erik, I'll give you a call. I don't do the just drop by think. Drives the wife nuts when people do that.
  20. #140
    Huntsville, Al
    Another few steps closer today.... work has let up some.... so spent the FULL day at it.... Seat heaters installed, some more wiring, installed the shifter for the final time, installed a good chunk of the aluminum.. the back is completely done, cockpit floors are in, battery installed and cables run...man I guess I got a lot done now that I am typing it all out... only 3 pictures but the under car shot looks great with the powdered panels....too bad it won't be seen.... anyway... closer to first start!
  21. #141
    Wow: This Chassis Truly Lends Itself To Ground Effects.
    It looks like you could totally smooth things out under the entire chassis if there is room enough to move the drive line up just a smidge.
  22. #142
    Huntsville, Al
    only a couple hours on it this morning.... oil filter relocation kit installed... turbo wastegate installed on driver's side header and have begun connecting the intake plumbing.... should look good....
  23. #143
    Pittsburgh, PA
    Erik,
    This looks great.
    Just out of idle curiosity, how is the fit of the aluminum panels so far? "Everything almost fits" was the old and largely accurate saying about the prior versions, and I'm curious about whether that's improved.
  24. #144
    NORTH CENTRAL CT
    Eric,
    Are the seat pans wide enough to install modern racing seats?
  25. #145
    Huntsville, Al
    So far, even for a beta, everything fit really really well! I think based on my size no problem on the seats...I will be mounting the seats shortly and you will see how much room there is
  26. #146
    Huntsville, Al
    only a few hours on it yesterday after my eye check up... course I couldn't see too great after....
    anyway, driver's side turbo header final install and wrap. Today I should finish up everything on the driver's side until first start....once the turbo stuff get's done should be cruising pretty steady... the green lantern took me about a month to do - so I think I am on track.
  27. #147
    Huntsville, Al
    didn't get as much done as I wanted....
    Driver's turbo now installed for the final time.... drain lines mocked up... need some line...cobra steering shaft "modified" to fit the coupe. (thanks john and mark)... I now have steering... installed radiator aluminum and placed radiator in the car. Alternator also went back in now that the turbo is in...the shorty headers and the alternator plug occupy the same space.... so I had to disassemble the plug and hard wire the alternator.... the AC and the shorty headers on the other side occupy the same place... so I will have to figure something out there (I have a plan already) . Hopefully I will move over to the pass side turbo tomorrow... I have to grind a bit on the frame to make rum for the driver's side drain line...also need to install the IC pump... getting close!
  28. #148
    Gorham, ME
    Nice progress Erik, starting to shape up nicely. All you guys are motoring through these cars a Mach speed 7.
  29. #149
    Ol Skool
    upstate NY
    Great build Erik! Looks like you may have almost enough rubber on it
  30. #150
    Huntsville, Al
    Closing in on that first start... all the extra crap for the turbos really slows this down... anyway... coolant is mostly in. Oil Filter is now in and filled. Both Turbos, headers and waste gates are installed and header wrap installed. Driver's side turbo oil return complete...still waiting on fittings for oil supply lines (which is the only reason I haven't started it) . Still have to bleed brakes and clutch and put fluids in the engine and tranny.... that should be the end of the mechanical and I can finish up the wiring after that...ordered my custom side pipes $$$$.... but they will look bad to the bone....so I had to have them.
    The lower radiator hose is Dayco 81491 Henry... you WILL need this. You also have to trim the aluminum to get the hose in there....on exit... mine contacts the sway bar... so I will address that next...
    it is looking like I should start it!
  31. #151
    Port Charlotte, FL
    Looking good Chief and thanks for the heads up on the hose.
    Henry
  32. #152
    The lower radiator hose is Dayco 81491. Henry... you WILL need this.
    Do you reckon those are available at NAPA?
    Port Charlotte, FL
    Mebbe!
    Henry
  34. #154
    Fayetteville WV
    Quote Originally Posted by 65 Cobra Dude View Post
    Mebbe!
    Henry
    Anyone know a good NAPA dealer near Tampa FL?
    1972 Corvette Stingray 350 c.i. Manual Steering & Brakes
    2003 H-D Softail Deuce 88 c.i. TwinCam
    Gen 3 Coupe Dreamer
  35. #155
    keep an eye on these two
  36. #156
    Huntsville, Al
    Well.............................................. ...
  37. #157
    And that boys & girls is a typical Erik build. Actually that's not 100% correct; he'd have had it running sooner but has cut back on the Red Bulls.
    Huntsville, Al
    lol......well in truth .. those turbos took a little more work to put in... work go in the way of course.... but it's running now! ... now I have to tidy everything up, hook up the intercoolers and carry down to house of power....get some numbers on this bad bod!!
  39. #159
    Fayetteville WV
    Erik,
    Wicked sounding! Great to see it running!
    Len
    Gen 3 Coupe Dreamer
  40. #160
    Gorham, ME
    Great stuff Erik, engine sounds good.
    What is the HP you are shooting for with this set up?
