Results 1 to 6 of 6
Thread: Fire Suppression System?
    Senior Member Blwalker105's Avatar
    I happen to have a Safecraft 10 lb fire suppression system left over from my plane build and have been toying with the idea of integrating it into my coupe. Is the 20 lbs installed weight worth the peace of mind knowing I will be most likely stuck in the car should both door latches be damaged in a collision or shunt?
    It is a pull cable release bottle with provisions for 2 nozzles. I would plumb one to the front fuel tank area and one aiming at the top side of the engine.
    Anyone running or thinking about anything similar?
    Leesburg, VA
    Retro recently used his fire suppression system:
    http://thefactoryfiveforum.com/showt...l=1#post253801
    I've seen them on a few R's.
    Bowling Green, KY
    I have a 10lb fire system in my R one nozzle for the cockpit, one in the fuel cell box and 2 in the engine compartment.
    I had one in my first roadster and one in my gt40. I'll have one I'm this Roadster build.
    OK, in it goes!
    Kirkland, WA
    I have a SPA system in my R and have 3 nozzles in the engine, (turbo, front of engine and fuel connections and lines), 3 in cockpit (side of driver, front of driver and fuel cell), 2 emergency levers, one for driver and one for corner workers).
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
