0
0
New engine for the 818
Could this engine LTG 2.0L Turbocharged Crate Engine by GM be installed in the 818? Why has this not been an option for the 818?
It has some great performance numbers.
The LTG is rated at 272 horsepower at 5,500 rpm and 295 lb.-ft. of torque at 3,000 rpm. Its torque curve is broad and robust, delivering 90 percent (260 lb.-ft.) of its peak torque from 1,700 rpm to 5,500 rpm – for a great feeling of immediate power at all speeds. Peak torque is sustained from 3,000 to 4,600 rpm.
Another option as the ecoboost is not available.
- You may not post replies
- You may not edit your posts
Forum Rules
