Haven't posted any progress in a while, mostly because there hasn't been any.
Did start on the interior insulation until the weather took over.
First made some cover plates for the roll bar tie ins in the trunk area. They are one piece. Caulked them then riveted to keep them in place
Then put insulation/sound deadening in the trunk.
This stuff is really easy to work with. It's not double sided bubble wrap but actual insulation between the two layers of aluminum foil.
Then switched to the passenger side compartment
Seams will be taped
Also started on the trunk side panels. Same insulation and vinyl covered.
Will glue these in place when I remove the body.
Also covered the shock tower covers
Unfortunately I've run out of vinyl, which I bought when living in CA. Trying to find matching stuff is proving to be difficult.
