While trying to pre fit the headers, it seems as if there is even less room between the bolt heads and the header pipes than I realized. I thought I was pretty well equipped with tools, but so far end wrenches, sockets, flair-nut crows foot, torque extender/adapter all do not fit on most of the bolts. A couple I can get a wrench or socket on, but that's it. And this is supposedly the EASY side. (Haven't even looked at the DS header yet.)
My next idea is to grind down a wrench or torque adapter to try and get one to fit, but before I ruin a $40 or $50 tool (I use SnapOn), that may not work, I'm coming to the experts for advise. Is there a special socket or wrench that I'm not aware of that is made for this problem? For those with these interference problems, do you have any special bolts that work? I see that the Stage 8 bolts are 6 point, which would allow an end wrench or crows foot to maybe work. Any and all help appreciated. I was supposed to have first start last month, but this is the last issue before start and now holding that up.
Thanks all.
If Brute Force doesn't work, you're not using enough of it. Basic Stuff: MK4 Complete Kit #8439, Wilwood's, 17" Halibrands. Extra Stuff: Stainless brake and fuel lines, Breeze cooling, Battery mount, SS Roll Bar. Old Fart Stuff: Heater, Seat Heaters, Footbox Fresh Air, Stereo, Keyless ignition, Power Steering, Hyd Clutch. Young & Dumb Stuff: 427w Dart, TKO600, 3 link Moser M9/Ford 9", 3.5:1, Eaton TruTrac Posi. Graduation Thread
