0
0
Outside door handles
Making progress on the door handles. However, I am now stuck again. The cable from the handle to the door bar is in place. Book says to connect clevis to the horizontal hole in the door latch, see picture. When connected there, the pulling action is to the rear of the door which doesn't trip the latch. I went back and reread the latch instructions and found a note about drilling a second hole in the latch arm but my latch is different. I do not have room for a second hole, nor would that hole change the angle of pull. Please reply with the magic trick to get thus convoluted piece of nonsense to work. Thanks20161219_165308.jpg
