Results 1 to 13 of 13
Thread: Custom heat extractor taillights in the works
Hybrid View
    Sep 2011
    I have been working on making some taillights for my GTM that are a little more appropriate. Going for a similar look as the 2017 Ford GT, but with some flair. They are custom made 1/2" acrylic diffusers for which I am having custom addressable LED rings made, which are controlled with 5v data from an Arduino Uno. There will be 4 rings, red all the time for parking lights, and get brighter with brakes. The outer two will light amber for turn signals, and the inner two will light white for reverse. I am also making a trim ring insert for the center to give them a turbine look. This ring will be gloss black or carbon fiber. If you look closely, you will see the detail in the inner ring, and that the inside is chamfered as well. Subtle but huge difference. Lastly, the center is open, with a concave pressed grill to add depth. Air will flow in the side scoops, and the four lights will serve as extra heat extraction points. Once my prototype is complete and working, I will CNC the final products for assembly. The outer ring will be lightly tinted and they will be done.
    Sep 2011
    Here is the pressed grill and outer ring
    Groove cut in for LED's
    Backing plate made
    Test fit
    Sep 2011
    Inner ring made
    Test fit again
    43 SMD LED's per ring layout
    Those are OUTSTANDING! Form, function, light weight, they have it all. The only issue I see with this light is that everyone will want some and they will be common on the GTM and every other custom exotic car. Very impressive.
    EDIT: Can't wait to see the first custom car that cuts the screens and runs their exhaust tips through a set of those.
    Sep 2011
    Quote Originally Posted by mikeinatlanta View Post
    Thank you Mike! I wouldn't mind making a few more sets to recuperate some costs, but there's something nice about having one-off parts.
    Then again, that's the beauty of what I do. I can remake these lights 1000 different ways by just changing the the chamfers, or roundovers, or even the grill mesh used for the middle. Heres an example of another insert I made beut decided it was too radical.
    As for exhaust, I thought about making some matching trim rings for the kooks tips, but I fear they will melt. They would need to be made 100% out of aluminum. It would be awesome to have them around the exhaust lighting as reverse or something.
    Apr 2015
    Andover, MA
    Are you routing these? Can you show some in-process pics?
    Nice work!
    Sep 2011
    Quote Originally Posted by ben1272 View Post
    Nice work!
    Yes, I used the router almost exclusively on this. I am right in North Chelmsford, you are more than welcome to swing by my shop any time and check it out. I can show you in person that way. Thank you!
    Apr 2015
    Andover, MA
    Quote Originally Posted by MTSCustoms View Post
    Thanks! I think I'd like to try making a set of these for the 818. I have not experienced any heat problems yet but have heard that the engine bay gets pretty warm! A fan positioned behind them could force heat out while standing still too.
    Dont be surprised if you see a PM from me!
    -Ben
    Nov 2016
    St Louis, MO
    ...I am having custom addressable LED rings made, which are controlled with 5v data from an Arduino Uno.
    WOW!!! I can't wait to see the finished product!
    Where are you having the custom addressable LED rings made? Just curious...
    Juan
    St Louis, MO
    Sep 2011
    Quote Originally Posted by juanfmc View Post
    Juan
    St Louis, MO
    I just asked on an Arduino forum and got very lucky when a guy who makes custom circuit boards contacted me and could make them, and happened to be local. Not sure of his business info or if he just does it for himself, but I will know if he does well in a few weeks.
    Senior Member Taz Rules's Avatar
    Dec 2012
    BC, Canada
    I. Love. Those.
    Don't show them to Stig. It would make one more thing he'd have to change on his car. LOL!
    (JK, Mike!)
    MONROEVILLE , NJ
    Wow, really innovative. Can't wait to see the finished product.
    Michael
    GTM 240
    Oct 2014
    Southern Pines, NC
    I'm REALLY liking these tail lights! have you decided to market them? and just looking for any updates on them, thanks for sharing!
