My transmission will only shift into first and back to neutral with clutch in or out. It will not shift back into second. It will not not rotate (move side to side) to access the other gears. Any idea what is causing this and how to fix it?
The transmission is a 2006 jdm six speed. It's shifting has been this way since I received it. I have converted it to two wheel drive and installed it along with a new clutch. I have used the starter to turn the motor over with the trans in neutral and in first gear.
