Results 1 to 5 of 5
Thread: Engine Hose Replacement
    Oklahoma City
    Have my donor disassembled, and started work on the engine 'simplification'. Many of the myriad of hoses on the engine are fairly hard especially those running close to / under the manifold. Should these hoses be purchased from Subaru or simply make them up from bulk hose? Any good source for I suspect 'metric' hose sizes?
    ~ Mark
    2001 NB Miata LS3 V8 440 rwhp
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Depends. If you do the simplification stuff like removing the air pump, evap, pcv, and getting aftermarket fuel rails, then there are very few hoses left. Some of the oem hoses are supposed to be firm... esp the ones that deal with crankcase vapors, and they have bends in them that you can't match with bulk hose.
    Here's a pretty thorough write up on hose replacement from NASIOC: http://forums.nasioc.com/forums/show....php?t=2614458
    Some others on here have some recommendations in their build threads.
    I am in the same boat - I've eliminated quite a bit from my donor motor and am now in the midst of what seems like a graduate degree on hose replacement/install. I'm a Subie Newbie so that doesn't help either.
    Oklahoma City
    Again, thanks for the input. I may be getting too concerned as all the items you mentioned will be done.
    ~ Mark
    Oklahoma City
    Thanks for the reference. Just got lazy and did not think to search there! Bookmarked it!
    Quote Originally Posted by mistasherm View Post
    ~ Mark
Clever Turn Signal
