Is there a map (with 'Stick Pins') to show where the various FF models have been sold?
~ Mark
2001 NB Miata LS3 V8 440 rwhp
That is strange. If I look at the 3rd item in list,
it shows a map of 818 cars. I have a winter home in Venice, Fl
and there is a blue icon on my street but
FFR order came from Mich and that is where
delivery will be in March. They should not
even be aware of Fl address. Touch blue icon
does not give any info like others do.
Ideas????
~ Mark
Go to the links on this page to enter your information.
http://thefactoryfiveforum.com/showt...l=1#post191569
I manage the new list and map. Like Bob mentioned you can enter new info or request changes using the info at the following link. http://thefactoryfiveforum.com/showt...l=1#post191569
This list is not managed by FFR and only contains info from builders that register at the link above.
Sorry if the map shows errors. I have to manually sync the spreadsheet to the map which I have not done in awhile. If you see something incorrect on the map please add a comment to the spreadsheet.
@frankc5r I'm not sure what your looking at I dont see any info logged near Venice, FL. I do have your location for Saline, Michigan and I just added your serial number. If the serial number is missing then it is because the builder/owner did not provide it.
818S Chassis #288 2.5L 323hp
joshuajach.com
Also, this is only for the 818 owners.
joshuajach.com
@frankc5r I'm not sure what your looking at I dont see any info logged near Venice, FL. I do have your location for Saline, Michigan and I just added your serial number. If the serial number is missing then it is because the builder/owner did not provide it.[/QUOTE]
Not sure why but blue icon is gone now. Do you have a link to latest map. Can't see my link in MI that you added using above link.
Thanks for doing this, Great resource!!
Thanks for doing this, Great resource!![/QUOTE]
That is the latest link for the map. I'll go ahead and sync it now, check it again in 10 mins.
joshuajach.com
