0
0
Header alignment
So after about ten years of enjoying our two mkII's and being off this forum asking tons of questions I'm back for a question.
put a set of elderbrock performer heads on a 5.0 ( from a 95 mustang) and bought 4 into 4 headers and side pipes. put heads on and the headers on and the are about a inch high
in the cut out of body where sidepipes bolt up. left to right they look lined up good. Does any one make wedge type gaskets for header to heads. Or something to angle them down a bit. Thought about lower engine down a little with motor mounts but not sure about that, cant have oil pan lower than frame. Any one have any ideas.
Thanks Dan
