Results 1 to 18 of 18
Thread: Should I paint the upper section of the steering shaft?
    Jacob's Avatar
    Rogers, AR
    Do most builders paint the upper section (nearest the driver) of the steering shaft? Looks to me like this will eventually rust if not protected...the lower section appears to be stainless and should be ok?
    Levy 306
    T5
    2015 Mustang IRS
    When in doubt hit it w/ some rattle can black. Not w/ this part specifically, but nearly every time I've not taken the time for some paint, I've ended up wishing I had. I like the Rustoleom Self Etching primer and their 'Hammered' paint for this because it dries quickly and is quite durable.
    Out Drivin' Gumball's Avatar
    Blackberry Township, IL
    Have you considered using one of the turn signal systems that a couple of the vendors here offer? If so, that will cover the upper shaft and provide a production car look.
    Later,
    Mk3.1 #7074
    I sprayed the end that shows through the dash with black and then sprayed the entire piece with clear.
    I will say prior to painting I had the upper shaft in and out a few times. Now that I sprayed it I can not get it to budge at all. Luckily I haven't needed to get it out again but I think putting the clear on the portion that slides into the lower shaft was a rookie mistake! Didn't really consider it at the time but I think I should have just cleared the portion that was visible.
    If you like the look and don't want to paint use Sharkhide Unlike clear, Sharkhide won't chip, peel, or yellow. Wipe it on with microfiber cloth and it dries in seconds to give you years of protection. If you ever need to re-coat just clean the surface and wipe more on. No need to sand or scuff up the surface. Sharkhide provides a very thin coating and is used mostly on bare aluminum but works on all metals.
    Dec 2014
    Gurnee, IL
    Took a different approach, used large heat shrink tubing on the part visible from inside.
    Quote Originally Posted by Alig2 View Post
    I like that idea. Could you post a picture of that?
    Jacob's Avatar
    Rogers, AR
    yes was actually considering the Russ Thompson setup...not too familiar with it but based on your note it would cover the upper exposed shaft..if it does then nothing to worry about! thanks
    Levy 306
    T5
    2015 Mustang IRS
    I do the same thing. Quick and easy. IMO
    Quote Originally Posted by Jacob View Post
    Here's a pic of how the Russ Thompson switch looks - not the best, but the unfortunately the best I have at the moment. It has a tube that extends well down behind the dash, so you won't see the upper portion of the steering shaft.
    Later,
    Mk3.1 #7074
    Better pic of the Russ Thompson switch assembly - the upper shaft will only protrude from this far enough to fit the steering wheel on the end. According to the instructions, you'll have to make sure there is a slight gap throughout the full rotation of the wheel both ways to avoid grounding out the switch between the housing and the back of the steering wheel, but that gap on mine is very small.
    Later,
    Mk3.1 #7074
    This pic shows just the tube of the Russ Thompson switch assembly mounted to the chassis - the "flange" with the actuating lever was off when this was taken. But, from this, you can see how the upper column is covered by the assembly.
    Later,
    Mk3.1 #7074
    And for those who haven't seen the full Russ Thompson assembly, here's a pic on the bench. I asked him to make mine with the actuator lever facing to the right (passenger) side of the car and to leave the switch off the end of the lever. I'm really happy with his craftsmanship and the function of the part.
    Later,
    Mk3.1 #7074
    Dec 2014
    Gurnee, IL
    Simple, looks like it was plastic dipped
    Jacob's Avatar
    Rogers, AR
    thanks to all for all the great feedback...puts me back on track!
    Levy 306
    T5
    2015 Mustang IRS
    Custer, SD
    I used a piece of black wire loom cover. -- Chuck
    Sep 2014
    Chrome it ;)
    Took a chrome hollow towel rod cut it to length and slid it over the shaft. Looks great!
    Then there is always the old school stainless steel thermos cap, that some builders used, if they weren't bothering with a column signal switch. It finished off in that area quite nicely. I also recall someone using a small stainless steel dog or cat bowl, for the same purpose.
