Russ' Garage
Page 2 of 2 FirstFirst 12
Results 41 to 45 of 45
Thread: Build your own switchback - turn/running flasher controllers
    You should check out McMaster-Carr. It is a US
    company but I checked on couple web sites who members
    live in canada and they got shipments w/o any
    problems. They have EVERYTHING!!! Give them a call to check.
    330-995-5500. Also look at web site.
    QC, Canada
    I've asked McMaster twice in the past 3 years and they don't deliver to residential addresses outside USA. Only commercials. It's not clear on their website which is why I asked twice, just in case they changed mind.
    But that's ok, I have still some tire repair rubber cement, I'll use that.
    Will start dismentling the Eagle Eyes later this week or next w-e (as soon as I get my new soldering iron). I expect 6 to 10h of work on these.
    818 chassis #181 powered by a '93 VW VR6 GT3582R ~400whp/wtq+
    Tracked May 27/July 26, 2017
    Official Bulid time 3077h, now at 3200, in inspection process
    Yes, I love Technology aquillen's Avatar
    NW Indiana
    If you make your own PCB using toner transfer process, don't forget to use paint or some app to mirror the image before you print your toner paper. ...
    NW Indiana
    If you are assembling from my pictures and drawings - please take note. Q2 the BS170 transistor comes in different packages. Some have a flat face, round back side (TO-92 case style). Others have a larger flat face and a smaller flat back instead of round. The drawing that shows parts layouts, shows the top looking down and the rounded side of Q2 faces away from Q1 - this is the correct orientation.
    With the round back it is easy to identify the front/back. And the numbers are printed on the flat side. With the large flat and smaller flat back, the numbers may be printed on the back side, which can lead you to install the transistor backward.
    The photograph of my boards shown above are built with the confusing transistor style, with the printing on what would normally be the rounded side the TO92 style case. So my transistor as shown in the photo has the back facing up (with the numbers visible).
    If you have the TO92 style BS170 with a flat on one side only, then you need to mount the transistor with the flat facing down, where you will NOT see the printed info on the part.
    A forum member found this out for us the hard way... I'm so used to these parts it didn't cross my mind to cover this before.
    QC, Canada
    Quote Originally Posted by aquillen View Post
    The clearance between the solder points and the inside of the aluminum housing is almost zero
    Mines aren't made of aluminum, they are full plastic, including the inside. I guess I got a different version and that I am immunized against possible shorts.
    Plus, the wire that comes out of the housing is glued with some kind of silicone or black glue that makes the wire very tight in place and won't really move. I know yours do.
    Also the lenses were very glued in place and only way to remove them was with a lot of heat and quite some force with a small flat screwdriver, before it would cool down.
