Results 1 to 3 of 3
Thread: Turn signals
    Nov 2016
    Petaluma, CA
    Turn signals
    In the 289 FIA complete kit, what is included as the provision for turn signals? I know that the wiring harness assumes there will be turn signals but how are the intended to be actuated by FFR? Switch on the steering column? Switches on the dash? What do most builders do to deal with turn signals?
    You should have received an ON-OFF-ON toggle switch, wired per the Ron Francis wiring instructions. Stock setup puts the switch on the dash. There are several other options. If you want a turn signal stalk on the steering column, many including me use the one from Russ Thompson. I'm assuming it would fit the 289 FIA. http://www.norcal-cobras.com/store/r...k3/mk3tss.html
    Nov 2016
    Petaluma, CA
    Thanks so much. It just so happens that Russ' location is about 15 miles from me. Who knew!
