Results 1 to 2 of 2
Thread: Converted Wilwood Floor Mounted Pedals to Period Correct
    Staring with Wilwood a dual master cylinder brake pedal and clutch pedal, I decided they just didn't look period correct. So I fabricated new pedal arms from steel plate and steel tubing with the same geometry as the Wilwood unites, had the pieces welded, then powdercoated. Now they look like they should
    The original dual master cylinder brake pedal
    The same pedal assembly with the new arm and AC pedal pad
    The original clutch pedal
    "The I.E." SoCal
    Very nice work Bill.
    __________________________
