0
0
Ebrake Cables For 98 Lincoln Calipers
I am building Roadster 8740 using a 98 Mustang Cobra as a donor and a 98 Lincoln IRS, complete with Lincoln calipers. With the Mustang donor brake handle what ebrake cable options do I have? Neither the donor cables nor the FFR supplied cables fit the Lincoln calipers. All the cable ends are 1/2" diameter and the caliper openings appear to be about 1/32" smaller.
I did something completely different. I used the Lincoln caliper cables, a custom bracket, an AC Delco equalizer, one FFR cable, and a Fiero handle to make it as close to how the MkVIII was setup as I could.
It was a lot of effort, but I'm really happy with how it turned out.
http://www.ffcars.com/forums/17-fact...rake-plan.html
Kyle
- You may not post replies
- You may not edit your posts
Forum Rules
