Engine Bay Wiring Question
Finishing up the wiring and have a quick question.
My setup is a carbureted 289 with a mechanical fuel pump, using the RF harness. There is an orange EFI/Coil wire coming from the battery feed block on the fuse panel and a blue EFI Crank Power wire from the ignition switch. Do these both get tied to the coil? The instructions and schematic are vague, probably due to the number of permutations I suppose.
Also (yes, I said one question, but...), the schematic shows a remote solenoid for the starter which is apparently no longer a thing with the complete kits. FFR said that it is not needed with the new starters. So, all the red wires that used to go to the remote solenoid per the schematic now get tied to the large lug on the starter solenoid and the blue wire from the ignition goes to the small lug? Just want to double check to avoid releasing the magic smoke.
Thanks!
FFR #8833 289 FIA 3-link
http://thefactoryfiveforum.com/showt...FIA-build-8833
