Thread: used or junk EJ Block
    Bowling Green, KY
    I am playing around with with some parts and looking for a bare block for test fitting.
    Mitch
    Just pulled my junked EJ205. Still tearing down, but was going to send block to recycler. Available if you want it, only problem is getting it to you.
    Bowling Green, KY
    Mike, sent you a PM
    DFW, Texas
    I got a bare block if you need it, as well.
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    I've got the EJ205 short block that just came out of my car. It has a bad rod bearing but should be rebuildable. If you are interested, PM me.
    Larry
    Bowling Green, KY
    PM Sent
