Results 1 to 3 of 3
Thread: My rear struts mount modifications
    Here is what I came up with to reinforce the rear struts mount bracket on the lower control arms of my GTM. I burnt-out the bushing that is unused, and installed a 3 inch long piece of 1.5 x1/4 DOM tubing, with a bracket welded to it. The hole is a little larger (40mm), so it is glued in, and pop riveted in place. I welded the struts bolt nut in place, then gusseted in between. I have a picture, but don't know how to post it. Maybe someone can tell me how. Lol
    Select the insert image icon (4th from the end) hopefully the image is on your computer, select from computer go to the location select it then upload.
    hope that helps
    Every time I upload a picture file, I get a message .... upload failed.
