Cutting holes for passenger side roll bar
Hi guys,
I'm in the planning stages and have a question. Is it possible to cut the holes for the passenger side roll bar by using the driver's side roll bar? The reason I ask is, I want to buy a passenger roll bar later on so I can take passengers on my local track. I don't want to buy it with the initial order and I don't want it on the car for cruising and car shows. My thought is to cut the holes and make plugs to cover the holes until I need the roll bar at the track. Any suggestions?
Purchased Complete Kit 6/9/2017, Delivered 9/4/2017, Rolling Chassis 3/30/2018, Engine Dyno'ed 3/4/2022, Engine installed 8/27/2022
Serial #9158
Yes, you could use the DS roll bar to confirm the proper hole locations for the front two holes. But you're going to need the actual PS roll bar to get the angled third leg. They're mirror images of each other. Lots of guys have the holes in the body with fillers when the roll bar isn't installed.
Build Thread and
Video.
Build Thread and
Video
Build Thread. Sold 11/9/2023.
I picked the "Cutouts included" option and only the driver side roll bar. When I picked up the car, the passenger side holes were pre-marked with sharpie but not cut (picked up the car 2 weeks ago), so it seems you would have what you are looking for. The only difference may be that they knew that I only had one roll bar selected, so if you buy both they may go ahead and cut both.
One of my questions was whether a PS roll bar could be temporarily removed - it sounds like it can from the post above.
I think your approaching it wrong and causing more work for yourself later on. Order both from FFR and fit them to the car. Then just remove the passenger side until you need it.
IowaBen
They mark the PS roll bar locations in all cases. But I would consider the marks as a starting point or suggestions. I would strongly recommend not cutting or drilling anything without the actual roll bar and checking carefully as you go. I just went through that on my current build with a PS roll bar. The factory markings were "close" but the final locations with the proper clearance were slightly different. Same for the factory cut holes on the DS. They needed to be adjusted to have the proper fit and clearance.
Yes, the rolls bars are removeable. Take the bolts out and they should slide out. But if it's something you're going to do all the time, you may need to adjust the bend on the main bar a bit to make it a true slip fit.
Build Thread and
Video.
Build Thread and
Video
It sounds like purchasing the roll bar up front is the best way to go. I was trying to figure out a way to spread out the initial cost a bit. Thanks!
Serial #9158
