Sharkhide
Thanks to all the info I've found on the forum, I think I have a pretty good idea what I need to do and watch out for when using Sharkhide on panels.
One question though - If I Sharkhide both sides of a panel, and then later want to apply bedliner or glue carpet/heat shield - can I apply those things directly to the Sharkhide? If not, will acetone sufficiently clean it off?
Just trying to understand the allowable sequence of events so I don't dig myself a hole.
Seasoned Citizen
If you apply bed liner or carpet adhesive on aluminum you need to scuff up the surface anyway so that will take off the Sharkhide.
