Front Alignment
Okay, time to get serious on the GTM.
I set the front suspension adjusters to the mid (neutral) position and I have about 1 1/2 degrees more caster on the left than the right. Left 1 1/2 deg, right 0 degrees. Is this common on a Gen I? Camber is nearly equal side to side, close to 0 degrees.
As noted on other posts, I plan to relocate the upper control arm mounting tabs to get more caster but assumed that each side needed to be moved the same amount. Nothing looks molested but I did buy the kit second hand with some work done. I do not have any history on the upper control arms. Any suggestions?
Ken
