Hey Craigfree.
Check out my video. Some have used it as a guide.
I'm sure most have more than 8 hour into getting the head lights to fit.
http://thefactoryfiveforum.com/conte...tall-procedure
Moonlight Performance
There will be gaps between the lense and the fender. The headlight won't fit excellently in the bucket but it will fit. Rotate the light back as far as you can (IE aim it upwards as much as possible). You will also need to pull the fender down with a bracket that attaches it to the nose. Lastly, it helps a lot if you add some brackets to the inside of the bumper to prop the headlight upwards. Check my build thread and you'll see exactly how I did it. I'm very happy with the results.
All I can say is thanks. I haven't tried it yet, but your methodology is way better.
