I am looking for the template to drill the holes into the aluminum panels. I bought a kit from someone and I cant find that template piece of metal.
Brian
Brian
The template is simply a strip of aluminum with holes with 2" spacing on one side, for the panel to panel rivets, and the other side is 3" spacing for the panel to chassis rivets. It's thin enough to use a pointed Sharpi, or magic marker, as we used to call them, thru the holes. I haven't measured the hole size, must be 1/8" or 3/16" at most.
I've made one by using a Stainless Steel Ruler and drilled it with a 1/8" bit on my press.
It works perfectly, but the stainless was a tad tough so use a high quality bit if you make one using a stainless ruler.
I will bet FFR will send you one for very little cost.
Someone is kind enough to send me one.. thanks guys
