Results 1 to 2 of 2
Thread: Wheels & Offsets
    Senior Member JOP33's Avatar
    Haslet, Texas
    Wheels & Offsets
    Generally speaking, if I stay within the wheel width, diameters & offset ranges of 5.5"-6", should I be ok with most any wheel? I am running the larger brakes, but looking at 17x8 in the front & 20x10 in the rear (no fenders). Foose Chrome Legends are specifically what I am looking at now, they are similar to the Torque Thrust but not exact.
    Seasoned Citizen NAZ's Avatar
    JOP33, I have TorqThrust wheels that fit the original FFR chassis (before I replaced it). The fronts are 18x9x5.0 back spacing, the rears are 18x10x5.74 back spacing. I'm also running the larger Wilwood brakes front & rear and you won't have much room (if any) with the 17" wheels on the front. That should give you an idea of what may fit your car.
