Well Used Member
New parts left over from MK4 complete kit
I have replaced some parts, and also not used some parts from a Mk4 complete kit. So instead of emptying boxes during the build, I'm filling boxes. That's just not right. For most of this stuff, I have no idea what the market value or worth is, so if you want to make me a fair offer, and I can recoup a little bit back from the thousands I've put into after market parts, that will probably be good enough. These are all FFR parts, and all are new, albeit 2 years old now. A few were mounted on the car, but none were ever run or driven before being taken back off. (i.e. the rear lower control arms were mounted and greased, but taken off before the car was ever driven.) Most were never even mounted on the car.
I'm still in the build, so I may have more stuff by the end of the year when (I hope, I hope) the car will be finished.
Here's a list of what I can see that I have:
Throttle pedal
Clutch cable
Idler pulley
Fuel filter
Fuel tank pickup 5/16"
Radiator Cooling Fan mount brackets
Wagner Headlight bulbs
Conical air filter (why that was in the kit I'll never know)
Oil Filter relocate kit
Stock FFR shifter
In line radiator cap housing (it's plastic though) plus some misc radiator couplings, SS hose, etc.
TKO electro/mechanical speedo drive (with 3.78 and 3.55 gears)
The standard key ignition switch and toggle switches
Best way to get me is PM, although that little notification at the top of the page is hard to see, but I'll try.
Parts sold: (thank you)
Simpson 5 point seat harness's (2 sets)
Roll Bar, DS black powder coat
1 1/8 inch Wilwood master cylinder (clutch M/C)
Radiator expansion/overflow tank (stainless)
Throttle cable
Steering rack, manual (with bushings, no tie rod ends)
3rd link retrofit bracket
Rear lower control arms
Parking brake handle/assembly
How much for both sets of the Simpson harnesses? PM Sent.
Pm sent on parking brake assembly and handle
Hey Boat-
Sent you a PM on a couple of the items. Thanks!
Boat, what do you need to get for the roll bar?
