Is there a way to remove the IRS spindles from the pumkin? I put the wrong axel in on the passanger side, and i can not get it out!
yes
pry bar in between the inner cv joint and the housing
The traveling Builder
717-773-5624
If it is the older style IRS (not the 2015 Mustang) they are held in with spring clips and are removed by prying between the pumpkin and axle hub. Some don't release easily so expect to have to pry with force. I don't recall having a left/right axle so am not sure how the wrong axle was installed. If you have the 2015 IRS, someone else may be able to help.
King
it is a 2015 IRS... and I have been beating on this thing to get it out. I will keep trying i guess! Thanks guys
2015's are the same way. Don't beat on it. Just a pry bar between the pumpkin and the axle hub. It should pop right out. I had a full pallet 2015 IRS for my build, and had to remove the stock axles.
Check about 4:15 in this video: https://www.youtube.com/watch?v=FEsCSvIO7KM
Try two pry bars. On opposite sides of each other.
After whacking mine hard for a few hours, and trying one pry bar I had no luck. I tried two, and they came out very easily with little to no force.
Martin
Previous forum name was "Fezzek"
We have them out... thanks guys... it took some force...
