0
0
upper control arm
Did anyone have a hard time getting both bolts to pass through on the upper control arm ?
It doesn't seem to line up on the holes !! I got the rear bolt through, but the front bolt would not line up with the rear hole on the bracket ..!! Uggh !! even tried vice versa ! If I got the front bolt through, the back bolt wouldn't go
Any advice ?
I see that your post has been here for a couple of months with no reply. So, did you find a resolution to your dilemma? I ask because now that I have started on my 33 HR I have the same issue. Very frustrating and disappointing. I can force the bolts to get the front suspension together, but feel uncomfortable thinking that all I've done is manage to tweak and bind the upper a-arms. Good luck with your build.
The biggest complaint on the forum about the FF 4 link is that it binds up. Save yourself some grief and purchase or make adjustable links they will help prevent binding. Gordon Levy sells lowers (LCA). I made my own lowers and uppers to extend the wheel base 1" to fit full fenders.
Sorry your having problems I hope your build gets smoother.
Good Luck
TomH33
Spohn Performance makes an adjustable set that has a very tough rebuildable joint:
http://www.spohn.net/shop/Factory-Fi...-MK4-Roadster/
Hope This Helps!
