Results 1 to 4 of 4
Thread: upper control arm
    upper control arm
    Did anyone have a hard time getting both bolts to pass through on the upper control arm ?
    It doesn't seem to line up on the holes !! I got the rear bolt through, but the front bolt would not line up with the rear hole on the bracket ..!! Uggh !! even tried vice versa ! If I got the front bolt through, the back bolt wouldn't go
    Any advice ?
    I see that your post has been here for a couple of months with no reply. So, did you find a resolution to your dilemma? I ask because now that I have started on my 33 HR I have the same issue. Very frustrating and disappointing. I can force the bolts to get the front suspension together, but feel uncomfortable thinking that all I've done is manage to tweak and bind the upper a-arms. Good luck with your build.
    Senior Member TomH33's Avatar
    Nov 2016
    Parker,CO
    The biggest complaint on the forum about the FF 4 link is that it binds up. Save yourself some grief and purchase or make adjustable links they will help prevent binding. Gordon Levy sells lowers (LCA). I made my own lowers and uppers to extend the wheel base 1" to fit full fenders.
    Sorry your having problems I hope your build gets smoother.
    Good Luck
    TomH33
    Spohn Performance makes an adjustable set that has a very tough rebuildable joint:
    http://www.spohn.net/shop/Factory-Fi...-MK4-Roadster/
    Hope This Helps!
