Valve stems for Halibrand wheels
Are the FFR Halibrand wheels supposed to come with valve stems? I just took my wheels and tires in to be mounted and the tire shop told me the Halibrand wheels needed a special valve stem. None of the stems they had would work and he didn't know where/what to order.
Mine did come with valve stems, which I did not use. I had some metal ones that fit that has a nut that tightens down with seal washers underneath. Take a good look in the boxes with the knockoff and lug covers, they were in one of those boxes.
Mine came with them. They were in one of the knock offs boxes.
http://thefactoryfiveforum.com/showt...e-build-thread
I checked. Not in there. They did send me 20 extra lug nuts??
I had the same issue. Valve stems were included with the previous vendor 17 inch wheels on #7750. But for the 18 inch wheels in the new kit, no valve stems. I called Factory Five and they said they were no longer included. Since then, I've heard from several that they did receive them. Others that didn't. So I guess I'm not sure, but bottom line I didn't get any.
When I took my shiny new BF Goodrich Rival S tires to get mounted and balanced, the tire store had an issue getting either standard or bolt-in stems to fit. I called Factory Five from the tire store, and fortunately Jay knew exactly what valve stem to use (standard TR413 rubber pull-through) and gave me instructions to pass to the installer. Success! He even offered to speak directly with the installed, but wasn't necessary. Unfortunately, I don't remember exactly what the instructions were (I've slept of few times since then...) but maybe knowing the right valve stem will get things moving. Otherwise, call Jay. Good luck.
Build Thread and
Video.
Build Thread and
Video
Build Thread. Sold 11/9/2023.
Thanks, Courtney from FFR is sending me a set, next-day.
Straversi
I didnt get any lug nuts, but got stems (even though FFR mounted my tires).
Well Used Member
I guess you are already set, but I did have a small issue with the FFR supplied valve stems. I ended up not using them and getting some from America's Tire when I had my tires mounted. Here's the thread. http://thefactoryfiveforum.com/showt...nd-valve-stems
I forgot to take mine to the shop when I took my wheels in. They had ones that look exactly the same as the FFR ones. I would be a little afraid of a tire shop that told you that you needed special ones.
I have the 15" Halibrands. No stems with mine, but the shop seemed to have no problem. They did call and ask if I wanted the raised white letter facing in or out. This place usually deals with the ultra low profiles on the 20+" rims, so mine were a little off the beaten track for them. They got it done quickly though and the wheels/tires were all cleaned and wrapped up when I picked them up.
FFR #8833 289 FIA 3-link
http://thefactoryfiveforum.com/showt...FIA-build-8833
