Power door locks
I installed the donor power locks actuators to the door latches and a controller from Amazon (Docooler Car Remote Central Lock”, $16.99). There are two key fob remotes. I mounted the lock control module under the hood on the left side with its 12" antenna hidden. It works from at least 50 feet away, maybe further.
Wiring:
• Orange – ground
• White – to “close” (white, top post on actuator)
• Yellow – 12 volt power (“battery” fuse block)
• Orange/black – ground
• White/black – to “open” (blue, bottom post on actuator)
• Yellow/black - 12 volt power (“battery” fuse block)
• Black – ground
• Red - 12 volt power (“battery” fuse block)
• Brown – for parking lights, not used
• Green – for trunk release, not used
I have no key lock in either outside door handle so I added a manual unlock in case of a dead battery. I ran a narrow cable from the driver's door lock forward through the front of the door into the wheel well so I can pull it to unlock the door. It's a secret unlock so don't tell anyone!
