Front suspension woes, 818c
In the process of install the front suspension. Had a difficult time getting the lower control arm mounts to align. The left rear bushing had to be pried on to get the bolts to line up. Now the bushings are binding and appear to be sitting at an angle. I am not sure if I mixed up the rear bushings but have installed them with the flat side facing up and in with the side with the wave in it on the lower/outer mount. I have stamped steel arms from a 2006 wagon and was using the outer holes on the frame for mounting. Am I missing something?IMG_2774.JPGIMG_2776(1).JPG
Robert
Replied in other thread with same name.
