I began installing my driveshaft yesterday. Pulled the plug on my differential, filled it with fluid, plugged her back up. Then onto the drive shaft. I got it in place and the 4 bolts started fairly easily. After about halfway into the threads the bolts are binding. An impact wont budget them (cordless 20v) I'm not sure if I should go with the pneumatic impact or should these bolts be going in easier??
Onto the brake bleeding.
I filled the reservoir.
Used the hand held vacuum pump one man deal. It pulls a vacuum off of the passenger rear bleeder but when i open the bleeder screw i get no fluid. I have checked all of my connections and they all seem tight. I'll have someone else go over them if its possible that could be the problem.
Any help with this or my driveshaft issue would be greatly appreciated!
