Likes Likes:  2
Results 1 to 3 of 3
Thread: Sway bar bracket.??
    Sep 2011
    Sway bar bracket.??
    The rear sway bar brackets from my 2006 wagon donor have a distinctive bend or curve to them yet they need to mount to a flat surface. Bending them enough to fit seems extreme. Are the sedan brackets different? I'm sure these are the ones from the rear but I could be wrong.
    Robert
  2. Likes SamT01 liked this post
    Baldwinsville, NY
    The will get bent straight to fit OR do as I and many other have, buy these.https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    They fit well.
  4. Likes SamT01 liked this post
  5. #3
    I'll add to RDRP's comment about bending them straight: It happens as you install them. When you torque the bolts down, they flatten out and conform. I had the same question when I installed mine. The bend seemed too much for that to work properly but it actually worked out just fine.
    RDRP: Thanks for posting that link, I had not seen that before! I'm going to replace mine with those.
