Results 1 to 2 of 2
Thread: Aftermarket sway bar
    Has anyone fitted any aftermarket sway bars? I have a set of Cusco adjustable sways from my 05 STi, wanted to see if either one would work out well.
    Encinitas, CA
    The 818 has no mounting points for a sway bar in the rear, and I don't recall seeing anyone put one in back. The front is designed to use the stock 17mm rear donor sway bar. Lots go without any sway in front at all for a bit more over-steer; using anything larger than stock in front will probably increase under-steer too much. I think you would be better off selling the Cusco sways and if you want to tuning the 818's handling, do so with different spring rates.
