0
0
Temporary fan wiring.
I plan on go carting for the next few weeks before starting to fit the body and all. What i would like to do is temporarily mount the gauges and some how wire in a toggle switch to turn the fan on constantly. Any ideas on a simple way to wire in a temporary switch?? Thanks
Not a waxer
Just run it in parallel with the thermostatic switch by taking a pigtail from the dark green "fan thermo switch" wire to one side of an on/off toggle and connecting the other side of the switch to ground. You'll end up with automatic fan activation via the thermostatic switch as well as manual control by way of the toggle.
- You may not post replies
- You may not edit your posts
Forum Rules
