Thread: Has anyone successfully incorporated C5 active handling?
    Senior Member beeman's Avatar
    Indiana
    Has anyone been able to successfully do this? Including the electronic brake control module, the steering angle sensor, yaw sensor, etc? I think I'm going to try to do this unless it is not recommended.
    GTM #304 LPE 525hp LS3
    Banned
    Aug 2011
    Personally I'd stay away from using active handling or airbag systems from another vehicle. I've seen factory traction control and abs braking used but I'm not a fan of either of them. mikespms on the other forum has the most factory corvette systems incorporated in a GTM build that I've seen.
    Indiana
    Thanks for the reply. I do plan on using the Corvette ABS system definitely. It won't take much more work to install the accelerometer / yaw sensor /steering angle sensor. I like the idea of the system being able to specifically brake at one corner to effect the yaw rate. I'm also currently planning on an open differential, would the brake control module help modulate wheel spin?
    San Diego
    Just a heads up, but most people that track their cars regularly have a method to disable the traction control and dynamic handling features as, under race track conditions, the systems tend to be over used to the point that there are problems with the brakes. In other words, the brakes are used so much that they can fail. There are racing specific setups that can be user tuned that are used on the race tracks, but the Corvette and Mustang stock setups are notorious for creating problems on the race track. These are more occasional use, street minded type systems. In other words, more of "save my ***, nanny device" as opposed to a performance enhancement device that should be constantly utilized.
    www.myraceshop.com
    GTM solution kits
    Corvette and Race parts
    I wouldn't want the system and here is why:
     If you have any friends with C-5 or C-6 Corvettes, then please share this information with them.
     If you are attempting to slide or drift your C-5 or C-6 Corvette around a bit you WILL be surprised when your car goes out of control.
     The car literally grabs the brakes on an individual wheel or wheels in an attempt to straighten things out.
     It is why my brother sold his C-5 that his wife gave him for his 50th birthday and went on the hunt for the T/A that he bought.
    C-5 Corvette Active Handling System Video:
    https://youtu.be/LWNR-tvvwFo
    This system is used on the C-5 & C-6 platforms
    https://youtu.be/m5g4KIdGLfM
    Indiana
    Thanks guys. I really would like to keep the abs/traction control. Can these be kept independently?
    Indiana
    I looked into this further, I think I am going to install this. The Corvette guys unplug the steering position sensor when they track their cars, this disables the active handling but keeps the traction control and abs intact. Would be easy to place a toggle switch on the dash for this.
