Results 1 to 8 of 8
Thread: Spindle sheet metal
    Senior Member Lowrod's Avatar
    Nov 2015
    Mount Olive AL.
    Spindle sheet metal
    Picked up a pair of spindles from Pull-A-Parts, the sheet metal is in horrible condition. I would like to replace the sheet metal, is there a supply source/vendor that everyone's is using for this?image.jpgimage.jpg
    I would not run the splash guards. You do not see them on after market brakes.
    Agreed. Very few use them on FFRs.
    Senior Member Norm B's Avatar
    To reinforce the above two responses here are a couple of pictures with no dust shields installed.
    HTH
    Nom
    X4
    Super Moderator oldguy668's Avatar
    Pull them off and hammer them to get the aerodynamics correct, then frisbee them into the nearest dumpster...
    "Loyalty to the country always. Loyalty to the government when it deserves it".
    Mark Twain
    Raleigh NC, OIB NC
    Never even knew they existed till now
    Kevin
    MKIV #8234
    There is one function that they provide, and may be worth while to keep. The brake disks get hot and the dust shield acts as a heat shield to the steering parts.
