0
0
Fuel and brake lines
I need some clarity please. I have a tube full of lines that say brake line. Different sizes. I however do not have any fuel lines? Are the larger ones to be used as fuel lines? Or do I need to purchase fuel lines? I have been reading about Steel ones, and how they should be used for various reasons. Anyone have a recommendation? or link to some quality ones?
Larger are the fuel lines. Engine choice should be considered in determining fuel line size and if return is needed.
I believe that the standard brake line size included with the kit is 3/16" and that size is common throughout the system. Fuel lines are generally either 5/16" or 3/8" depending upon your engine choice and fuel flow requirements related to the type of induction; EFI, carburetor, etc, and whether or not you require a return line to the fuel tank. I am uncertain what size fuel lines are included in the kit.
Others here have more experience than me and and can likely provide better information.
The small 3/16 lines are your brake lines. The biggest in the tube, the 5/16, is your fuel pressure. The 1/4 lines are for return.
As stated before, what you use for fuel and return depends on your setup. These are stock sizes for the 87 - 93 5.0 Mustang.
