Results 1 to 11 of 11
Thread: Front brake backing plate with Willwood brakes.
    Sep 2011
    Fitting the brakes to the hubs and verified the discs hit the backing plates, then against my better judgement, I consulted the included instructions, they state the backing plates must be trimmed to about 6 1/2" in diameter by a professional machinist. It seems to me after trimming there is not much backing plate left and it also appears this would remove the mounting holes needed to attach them, and thirdly, there doesn't seem to be much point in having them any more after trimming except maybe to keep dust out of the bearing. I am inclined just to leave them off entirely. Thoughts?
    Robert
    Feb 2013
    Westminster, MD
    I scrapped mine. You will want to make a heat shield for the outer rod ends.
    Kirkland, WA
    I have the Wilwood 4 piston calipers/rotor and my shields fit w/o any altering, I'm using 2002 spindles.
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    Banned
    Are you sure it's not supposed to be 6.5" radius?
    Even so, a backing plate that doesn't closeout the wheel isn't going to do much good against debris lodging between the caliper and rim, but will block off any extra cooling air flow you might be able to benefit from by removing it entirely.
    Kirkland, WA
    Quote Originally Posted by phil1734 View Post
    Not really, plus it gives you a place to mount air duct if you want
    Tony Nadalin
    Banned
    Most OEM backing plates don't have duct attachment points. If we want to make custom ones as recommend above that's another story.
    Kirkland, WA
    Most all backing plates have attachment points for hoses, you may have to do some fabrication. There is no issue using the backing plates causing heat on the track.
    Tony Nadalin
    Aug 2012
    Long Island
    I removed mine altogether and purchased a set of these:
    http://www.lapponline.com/index.php?...roducts_id=186
    they bolt to the factory dust shield mounts.
    Feb 2013
    Westminster, MD
    ABS sensor cooler!
    Aug 2012
    Long Island
    Quote Originally Posted by SixStar View Post
    ABS sensor cooler!
    lol yup, plus it has a piece of rubber on there so the wire doesn't chafe. totally luxe.
    Do you have a picture of what this looks like on your 818? Where did you run the ducts to?
