Just.. curious, but any reason why this wouldn't work (fitment wise) in a 33?
http://www.edelbrock.com/automotive/...d-coyote.shtml
Should be no reason it wont fit, Need a photo of the back of the engine to really tell.
Not sure 785 horsepower would be enough.
Be sure there is a tune for the control pack, the electronics are different than a mustang.
FFinisher/AKA RE63
not for a hot rod,
Stock Oil pan works in the hot rod, not in a roadster or coupe
FFinisher/AKA RE63
you will need to remove alternator, cut off mounting boss & remount alternator backwards on the passenger side of the engine. (not really a big problem, just need to get a solid pulley for the alternator as the stock one is clutched & it needs to turn backwards from original).
But all of this is the same for any Coyote engine in the Hot Rod.
Nevin, AKA H. R. Lucky
33 Hot Rod sn 524 build started 3/18/2013, First Start-5/09/2015, Go Cart-6/01/2015
5.0 Coyote engine, 9in. Ford rear, 4 Link, Wilwood 12in. front brakes
AC, power steering, FFR 17/18in. Hot Rod wheels
