Thread: Edelbrock Coyote Fitment?
    Just.. curious, but any reason why this wouldn't work (fitment wise) in a 33?
    http://www.edelbrock.com/automotive/...d-coyote.shtml
    Bourne-Cape Cod, MA
    Should be no reason it wont fit, Need a photo of the back of the engine to really tell.
    Not sure 785 horsepower would be enough.
    Be sure there is a tune for the control pack, the electronics are different than a mustang.
    FFinisher/AKA RE63
    Id also need a different oil pan?
    Bourne-Cape Cod, MA
    not for a hot rod,
    Stock Oil pan works in the hot rod, not in a roadster or coupe
    FFinisher/AKA RE63
    Jun 2012
    CrossRoads, Pa.
    you will need to remove alternator, cut off mounting boss & remount alternator backwards on the passenger side of the engine. (not really a big problem, just need to get a solid pulley for the alternator as the stock one is clutched & it needs to turn backwards from original).
    But all of this is the same for any Coyote engine in the Hot Rod.
    Nevin, AKA H. R. Lucky
