Results 1 to 3 of 3
Thread: Front Spindals when using the 15" Vintage Halibrands
    Senior Member Lowrod's Avatar
    Nov 2015
    Mount Olive AL.
    Need some guidance, what spindals are required when using the 15" vintage Halibrands from FFR?
    Are you restricted to the 87-93 year or can you use the 00-04?
    I would like to use newer parts if possible.
    Any Mustang spindle up to 2004 as well as the FFR proprietary version. If going with donor pieces the '94 and '95 spindles are preferred due to better geometry for reduced bump steer in addition to keeping the wheels tucked in a bit tighter.
    Nov 2015
    Mount Olive AL.
    Thanks for the info Jeff
