I - and many others who have posted here and elsewhere - have long held the belief that poly bushings used in control arms should be lubricated only on the inside of the bushing, on the inner steel sleeve, and on the outer flanges (if applicable). Interestingly, many posts on other technical and racing forums - as well as the actual instructions from poly bushing manufacturers - advise also lubricating the outside of the bushing and inside of the steel control arm bushing housing sleeve.
The conventional wisdom has been that the bushing should remain fixed in the control arm and only rotate around the inner steel sleeve. I am beginning to question how much difference that actually makes. This is a practical matter for me, since I am building my Challenge car to ST2 spec, and have the 2015 Mustang IRS option. I am unable, when the assembly is fully torqued, to get all of the bushings to rotate with the control arm around the inner metal sleeve; the slip surface is also occurring within the control arm.
Which leads me to my question: does anyone have significant experience with this issue in an extended Street or race application? I have looked everywhere and can't find an answer to this question, which I would think is commonly encountered.
Bill
