I think I remember reading about someone who used riv-nuts and screws to hold on side sails rather than rivets. I'd like to use screws so that I can easily remove for dealing with brake/clutch lines and coolant line. Each has at least one fitting under the side sail and I'd hate to have to drill rivets to get body apart.
I'm sure some of you out there have pondered the same question. What do you all think? I was thinking of using the riv-nuts supplied by FFR with the flanged button screws they provide.
-Ben
